Time Before: 0.00669 seconds
Time After: 0.01376 seconds
Time Taken: 0.00706 seconds
Time Before: 0.01389 seconds
Time After: 0.01434 seconds
Time Before: 0.01463 seconds
Time After: 0.01476 seconds
Time Before: 0.01556 seconds
Time After: 0.01790 seconds
Time Taken: 0.00235 seconds
Time Before: 0.01483 seconds
Time After: 0.02334 seconds
Time Taken: 0.00851 seconds
Time Before: 0.02939 seconds
Time After: 0.02983 seconds
Time Before: 0.03242 seconds
Time After: 0.03367 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.02862 seconds
Time After: 0.03395 seconds
Time Taken: 0.00533 seconds
Memory After: 2,261.703 KB
Time Before: 0.04971 seconds
Time After: 0.04992 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.06015 seconds
Time After: 0.06145 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.06918 seconds
Time After: 0.06939 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.07192 seconds
Time After: 0.07347 seconds
Time Taken: 0.00155 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=102993' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.09017 seconds
Time After: 0.09041 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
