Time Before: 0.02223 seconds
Time After: 0.03039 seconds
Time Taken: 0.00815 seconds
Time Before: 0.03050 seconds
Time After: 0.03101 seconds
Time Before: 0.03129 seconds
Time After: 0.03142 seconds
Time Before: 0.03232 seconds
Time After: 0.03503 seconds
Time Taken: 0.00271 seconds
Time Before: 0.03148 seconds
Time After: 0.03902 seconds
Time Taken: 0.00754 seconds
Time Before: 0.04773 seconds
Time After: 0.04813 seconds
Time Before: 0.04963 seconds
Time After: 0.05097 seconds
Time Taken: 0.00134 seconds
Time Before: 0.04703 seconds
Time After: 0.05122 seconds
Time Taken: 0.00419 seconds
Time Before: 0.08117 seconds
Time After: 0.08133 seconds
Time Before: 0.09950 seconds
Time After: 0.10076 seconds
Time Before: 0.10978 seconds
Time After: 0.10996 seconds
Time Before: 0.11212 seconds
Time After: 0.11358 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=103044', badlocation = 1 WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.13050 seconds
Time After: 0.13080 seconds
Memory Before: 4,288.977 KB
Memory After: 4,289.203 KB
