Time Before: 0.00133 seconds
Time After: 0.00179 seconds
Time Before: 0.00186 seconds
Time After: 0.00229 seconds
Time Before: 0.00253 seconds
Time After: 0.00267 seconds
Time Before: 0.00330 seconds
Time After: 0.00628 seconds
Time Taken: 0.00298 seconds
Time Before: 0.00272 seconds
Time After: 0.01093 seconds
Time Taken: 0.00821 seconds
Time Before: 0.01273 seconds
Time After: 0.01308 seconds
Time Before: 0.01537 seconds
Time After: 0.01656 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01215 seconds
Time After: 0.01674 seconds
Time Taken: 0.00460 seconds
Time Before: 0.02168 seconds
Time After: 0.02180 seconds
Time Before: 0.02375 seconds
Time After: 0.02497 seconds
End call of global.php: 0.027509927749634
Time Before: 0.02903 seconds
Time After: 0.02918 seconds
Time Before: 0.03178 seconds
Time After: 0.03320 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=103061', badlocation = 1
Time Before: 0.04605 seconds
Time After: 0.04630 seconds
Page generated in 0.045129060745239 seconds with 9 queries, spending 0.0082404613494873 doing MySQL queries and 0.036888599395752 doing PHP things.
