Time Before: 0.00141 seconds
Time After: 0.00197 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00204 seconds
Time After: 0.00248 seconds
Time Before: 0.00271 seconds
Time After: 0.00286 seconds
Time Before: 0.00353 seconds
Time After: 0.00636 seconds
Time Taken: 0.00284 seconds
Time Before: 0.00292 seconds
Time After: 0.00970 seconds
Time Taken: 0.00679 seconds
Time Before: 0.01146 seconds
Time After: 0.01168 seconds
Time Before: 0.01413 seconds
Time After: 0.01537 seconds
Time Before: 0.01092 seconds
Time After: 0.01553 seconds
Time Taken: 0.00461 seconds
Time Before: 0.02061 seconds
Time After: 0.02076 seconds
Time Before: 0.02249 seconds
Time After: 0.02372 seconds
Time Before: 0.02656 seconds
Time After: 0.02672 seconds
Time Before: 0.02877 seconds
Time After: 0.03020 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=103063', badlocation = 1 WHERE sessionhash = '19bddeacfb649beeea65b05d036d70bd'
Time Before: 0.04282 seconds
Time After: 0.04314 seconds
