Time Before: 0.00264 seconds
Time After: 0.00325 seconds
Time Taken: 0.00061 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.00332 seconds
Time After: 0.00403 seconds
Time Taken: 0.00070 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.00428 seconds
Time After: 0.00442 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.00523 seconds
Time After: 0.00851 seconds
Time Taken: 0.00328 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.00447 seconds
Time After: 0.01189 seconds
Time Taken: 0.00742 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.01423 seconds
Time After: 0.01462 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.01712 seconds
Time After: 0.01853 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.01362 seconds
Time After: 0.01871 seconds
Time Taken: 0.00510 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.02568 seconds
Time After: 0.02586 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.03514 seconds
Time After: 0.03641 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
End call of global.php: 0.038039922714233
Time Before: 0.04439 seconds
Time After: 0.04460 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.04666 seconds
Time After: 0.04815 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
SET lastactivity = 1773143168, location = '/forums/private.php?do=newpm&explain=1&u=103064', badlocation = 1
WHERE sessionhash = 'fb8546df1d172120a5a514bbe0406f9a'
Time Before: 0.06157 seconds
Time After: 0.06191 seconds
Memory Before: 5,999.000 KB
Memory After: 5,999.211 KB
Page generated in 0.0606689453125 seconds with 9 queries, spending 0.0094075202941895 doing MySQL queries and 0.051261425018311 doing PHP things.
