Time Before: 0.02178 seconds
Time After: 0.02720 seconds
Time Taken: 0.00542 seconds
Time Before: 0.02731 seconds
Time After: 0.02771 seconds
Time Before: 0.02795 seconds
Time After: 0.02808 seconds
Time Before: 0.02893 seconds
Time After: 0.03160 seconds
Time Taken: 0.00267 seconds
Time Before: 0.02816 seconds
Time After: 0.03560 seconds
Time Taken: 0.00744 seconds
Time Before: 0.04459 seconds
Time After: 0.04502 seconds
Time Before: 0.04642 seconds
Time After: 0.04764 seconds
Time Before: 0.04390 seconds
Time After: 0.04786 seconds
Time Taken: 0.00396 seconds
Time Before: 0.09022 seconds
Time After: 0.09041 seconds
Time Before: 0.10697 seconds
Time After: 0.10827 seconds
Time Before: 0.12119 seconds
Time After: 0.12136 seconds
Time Before: 0.12384 seconds
Time After: 0.12537 seconds
Time Taken: 0.00153 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=103067', badlocation = 1 WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.14178 seconds
Time After: 0.14474 seconds
Time Taken: 0.00296 seconds
Memory Before: 4,288.977 KB
Memory After: 4,289.203 KB
