Time Before: 0.00149 seconds
Time After: 0.00192 seconds
Time Before: 0.00199 seconds
Time After: 0.00240 seconds
Time Before: 0.00274 seconds
Time After: 0.00290 seconds
Time Before: 0.00378 seconds
Time After: 0.00625 seconds
Time Taken: 0.00247 seconds
Time Before: 0.00298 seconds
Time After: 0.01041 seconds
Time Taken: 0.00744 seconds
Time Before: 0.01232 seconds
Time After: 0.01270 seconds
Time Before: 0.01524 seconds
Time After: 0.01640 seconds
Time Taken: 0.00117 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01170 seconds
Time After: 0.01665 seconds
Time Taken: 0.00496 seconds
Memory After: 2,261.820 KB
Time Before: 0.02241 seconds
Time After: 0.02261 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02437 seconds
Time After: 0.02559 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.027302980422974
Time Before: 0.02867 seconds
Time After: 0.02882 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03198 seconds
Time After: 0.03344 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1789128408, location = '/forums/private.php?do=newpm&explain=1&u=103077', badlocation = 1
Time Before: 0.04731 seconds
Time After: 0.04763 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
Page generated in 0.046308040618896 seconds with 9 queries, spending 0.0079305171966553 doing MySQL queries and 0.038377523422241 doing PHP things.
