Time Before: 0.00141 seconds
Time After: 0.00198 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00205 seconds
Time After: 0.00258 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00286 seconds
Time After: 0.00302 seconds
Time Before: 0.00376 seconds
Time After: 0.00646 seconds
Time Taken: 0.00270 seconds
Time Before: 0.00307 seconds
Time After: 0.00982 seconds
Time Taken: 0.00675 seconds
Time Before: 0.01170 seconds
Time After: 0.01192 seconds
Time Before: 0.01450 seconds
Time After: 0.01581 seconds
Time Taken: 0.00131 seconds
Time Before: 0.01115 seconds
Time After: 0.01598 seconds
Time Taken: 0.00482 seconds
Time Before: 0.02109 seconds
Time After: 0.02122 seconds
Time Before: 0.02317 seconds
Time After: 0.02447 seconds
End call of global.php: 0.026190996170044
Time Before: 0.02748 seconds
Time After: 0.02761 seconds
Time Before: 0.02961 seconds
Time After: 0.03103 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=103082', badlocation = 1
Time Before: 0.04360 seconds
Time After: 0.04392 seconds
Page generated in 0.042680025100708 seconds with 9 queries, spending 0.0082411766052246 doing MySQL queries and 0.034438848495483 doing PHP things.
