Time Before: 0.00242 seconds
Time After: 0.00311 seconds
Time Taken: 0.00069 seconds
Time Before: 0.00321 seconds
Time After: 0.00362 seconds
Time Before: 0.00388 seconds
Time After: 0.00406 seconds
Time Before: 0.00496 seconds
Time After: 0.00732 seconds
Time Taken: 0.00237 seconds
Time Before: 0.00414 seconds
Time After: 0.01271 seconds
Time Taken: 0.00857 seconds
Time Before: 0.01510 seconds
Time After: 0.01533 seconds
Time Before: 0.01790 seconds
Time After: 0.01929 seconds
Time Taken: 0.00139 seconds
Time Before: 0.01432 seconds
Time After: 0.01954 seconds
Time Taken: 0.00522 seconds
Time Before: 0.02572 seconds
Time After: 0.02589 seconds
Time Before: 0.02778 seconds
Time After: 0.02923 seconds
Time Before: 0.03223 seconds
Time After: 0.03240 seconds
Time Before: 0.03459 seconds
Time After: 0.03604 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=103093', badlocation = 1 WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.04880 seconds
Time After: 0.04904 seconds
Memory Before: 4,288.977 KB
Memory After: 4,289.203 KB
