Time Before: 0.01948 seconds
Time After: 0.02940 seconds
Time Taken: 0.00992 seconds
Time Before: 0.02950 seconds
Time After: 0.02995 seconds
Time Before: 0.03014 seconds
Time After: 0.03037 seconds
Time Before: 0.03102 seconds
Time After: 0.03310 seconds
Time Taken: 0.00208 seconds
Time Before: 0.03042 seconds
Time After: 0.03740 seconds
Time Taken: 0.00697 seconds
Time Before: 0.04701 seconds
Time After: 0.04721 seconds
Time Before: 0.04985 seconds
Time After: 0.05101 seconds
Time Taken: 0.00116 seconds
Time Before: 0.04640 seconds
Time After: 0.05120 seconds
Time Taken: 0.00481 seconds
Time Before: 0.10416 seconds
Time After: 0.10435 seconds
Time Before: 0.23880 seconds
Time After: 0.24005 seconds
Time Before: 0.25136 seconds
Time After: 0.25157 seconds
Time Before: 0.25466 seconds
Time After: 0.25610 seconds
UPDATE session SET lastactivity = 1784817724, location = '/forums/private.php?do=newpm&explain=1&u=103096' WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.27505 seconds
Time After: 0.27528 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
