Time Before: 0.00184 seconds
Time After: 0.00246 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00256 seconds
Time After: 0.00323 seconds
Time Taken: 0.00066 seconds
Time Before: 0.00348 seconds
Time After: 0.00364 seconds
Time Before: 0.00455 seconds
Time After: 0.00675 seconds
Time Taken: 0.00220 seconds
Time Before: 0.00372 seconds
Time After: 0.01222 seconds
Time Taken: 0.00850 seconds
Time Before: 0.01417 seconds
Time After: 0.01458 seconds
Time Before: 0.01716 seconds
Time After: 0.01842 seconds
Time Before: 0.01356 seconds
Time After: 0.01859 seconds
Time Taken: 0.00503 seconds
Time Before: 0.02454 seconds
Time After: 0.02466 seconds
Time Before: 0.02677 seconds
Time After: 0.02828 seconds
Time Taken: 0.00151 seconds
End call of global.php: 0.031131029129028
Time Before: 0.03284 seconds
Time After: 0.03300 seconds
Time Before: 0.03632 seconds
Time After: 0.03788 seconds
Time Taken: 0.00156 seconds
SET lastactivity = 1783209363, location = '/forums/private.php?do=newpm&explain=1&u=103106'
Time Before: 0.05199 seconds
Time After: 0.05229 seconds
Memory Before: 4,289.063 KB
Memory After: 4,289.289 KB
Page generated in 0.051059007644653 seconds with 9 queries, spending 0.0083534717559814 doing MySQL queries and 0.042705535888672 doing PHP things.
