Time Before: 0.00161 seconds
Time After: 0.00207 seconds
Time Before: 0.00214 seconds
Time After: 0.00251 seconds
Time Before: 0.00269 seconds
Time After: 0.00280 seconds
Time Before: 0.00364 seconds
Time After: 0.00615 seconds
Time Taken: 0.00251 seconds
Time Before: 0.00285 seconds
Time After: 0.01109 seconds
Time Taken: 0.00824 seconds
Time Before: 0.01315 seconds
Time After: 0.01359 seconds
Time Before: 0.01639 seconds
Time After: 0.01764 seconds
Time Before: 0.01244 seconds
Time After: 0.01788 seconds
Time Taken: 0.00543 seconds
Time Before: 0.02437 seconds
Time After: 0.02451 seconds
Time Before: 0.02677 seconds
Time After: 0.02812 seconds
Time Taken: 0.00135 seconds
End call of global.php: 0.030771017074585
Time Before: 0.03224 seconds
Time After: 0.03243 seconds
Time Before: 0.03475 seconds
Time After: 0.03640 seconds
Time Taken: 0.00165 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=103130', badlocation = 1
WHERE sessionhash = '32502f71822f8bf82bf8c86767d671b1'
Time Before: 0.05049 seconds
Time After: 0.05081 seconds
Page generated in 0.049558877944946 seconds with 9 queries, spending 0.0083482265472412 doing MySQL queries and 0.041210651397705 doing PHP things.
