Time Before: 0.00611 seconds
Time After: 0.00850 seconds
Time Taken: 0.00239 seconds
Time Before: 0.00861 seconds
Time After: 0.00897 seconds
Time Before: 0.00918 seconds
Time After: 0.00931 seconds
Time Before: 0.01009 seconds
Time After: 0.01237 seconds
Time Taken: 0.00228 seconds
Time Before: 0.00936 seconds
Time After: 0.01581 seconds
Time Taken: 0.00645 seconds
Time Before: 0.01918 seconds
Time After: 0.01943 seconds
Time Before: 0.02208 seconds
Time After: 0.02330 seconds
Time Before: 0.01863 seconds
Time After: 0.02353 seconds
Time Taken: 0.00490 seconds
Time Before: 0.03636 seconds
Time After: 0.03650 seconds
Time Before: 0.04174 seconds
Time After: 0.04296 seconds
End call of global.php: 0.044615983963013
Time Before: 0.04654 seconds
Time After: 0.04671 seconds
Time Before: 0.04866 seconds
Time After: 0.05010 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=103132', badlocation = 1
Time Before: 0.06338 seconds
Time After: 0.06368 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.062463998794556 seconds with 9 queries, spending 0.0075030326843262 doing MySQL queries and 0.054960966110229 doing PHP things.
