Time Before: 0.00145 seconds
Time After: 0.00195 seconds
Time Before: 0.00202 seconds
Time After: 0.00258 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00282 seconds
Time After: 0.00298 seconds
Time Before: 0.00372 seconds
Time After: 0.00588 seconds
Time Taken: 0.00215 seconds
Time Before: 0.00303 seconds
Time After: 0.00990 seconds
Time Taken: 0.00687 seconds
Time Before: 0.01168 seconds
Time After: 0.01204 seconds
Time Before: 0.01454 seconds
Time After: 0.01584 seconds
Time Before: 0.01109 seconds
Time After: 0.01606 seconds
Time Taken: 0.00497 seconds
Time Before: 0.02199 seconds
Time After: 0.02216 seconds
Time Before: 0.02391 seconds
Time After: 0.02521 seconds
Time Before: 0.02927 seconds
Time After: 0.02953 seconds
Time Before: 0.03241 seconds
Time After: 0.03391 seconds
Time Taken: 0.00150 seconds
UPDATE session SET lastactivity = 1784848519, location = '/forums/private.php?do=newpm&explain=1&u=103135', badlocation = 1 WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.04665 seconds
Time After: 0.04692 seconds
Memory Before: 4,912.320 KB
Memory After: 4,912.531 KB
