Time Before: 0.00193 seconds
Time After: 0.00276 seconds
Time Taken: 0.00083 seconds
Time Before: 0.00286 seconds
Time After: 0.00332 seconds
Time Before: 0.00357 seconds
Time After: 0.00375 seconds
Time Before: 0.00470 seconds
Time After: 0.00829 seconds
Time Taken: 0.00359 seconds
Time Before: 0.00383 seconds
Time After: 0.01323 seconds
Time Taken: 0.00940 seconds
Time Before: 0.01499 seconds
Time After: 0.01550 seconds
Time Before: 0.01680 seconds
Time After: 0.01796 seconds
Time Taken: 0.00116 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01446 seconds
Time After: 0.01813 seconds
Time Taken: 0.00367 seconds
Memory After: 2,261.820 KB
Time Before: 0.02291 seconds
Time After: 0.02303 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02470 seconds
Time After: 0.02590 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.027537822723389
Time Before: 0.02880 seconds
Time After: 0.02906 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03098 seconds
Time After: 0.03243 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1788893565, location = '/forums/private.php?do=newpm&explain=1&u=103161'
Time Before: 0.04450 seconds
Time After: 0.04474 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
Page generated in 0.043646812438965 seconds with 9 queries, spending 0.0091719627380371 doing MySQL queries and 0.034474849700928 doing PHP things.
