Time Before: 0.00204 seconds
Time After: 0.00263 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00273 seconds
Time After: 0.00315 seconds
Time Before: 0.00342 seconds
Time After: 0.00356 seconds
Time Before: 0.00441 seconds
Time After: 0.00747 seconds
Time Taken: 0.00306 seconds
Time Before: 0.00364 seconds
Time After: 0.01292 seconds
Time Taken: 0.00928 seconds
Time Before: 0.01543 seconds
Time After: 0.01582 seconds
Time Before: 0.01852 seconds
Time After: 0.01982 seconds
Time Taken: 0.00131 seconds
Time Before: 0.01472 seconds
Time After: 0.02008 seconds
Time Taken: 0.00535 seconds
Time Before: 0.02732 seconds
Time After: 0.02746 seconds
Time Before: 0.02994 seconds
Time After: 0.03234 seconds
Time Taken: 0.00240 seconds
End call of global.php: 0.034978866577148
Time Before: 0.03657 seconds
Time After: 0.03679 seconds
Time Before: 0.03999 seconds
Time After: 0.04326 seconds
Time Taken: 0.00328 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=103188'
Time Before: 0.05850 seconds
Time After: 0.05892 seconds
Page generated in 0.057123899459839 seconds with 9 queries, spending 0.011783599853516 doing MySQL queries and 0.045340299606323 doing PHP things.
