Time Before: 0.02085 seconds
Time After: 0.03164 seconds
Time Taken: 0.01079 seconds
Time Before: 0.03171 seconds
Time After: 0.03219 seconds
Time Before: 0.03244 seconds
Time After: 0.03259 seconds
Time Before: 0.03337 seconds
Time After: 0.03562 seconds
Time Taken: 0.00225 seconds
Time Before: 0.03266 seconds
Time After: 0.04002 seconds
Time Taken: 0.00736 seconds
Time Before: 0.05186 seconds
Time After: 0.05228 seconds
Time Before: 0.05481 seconds
Time After: 0.05602 seconds
Time Before: 0.05114 seconds
Time After: 0.05622 seconds
Time Taken: 0.00508 seconds
Time Before: 0.08028 seconds
Time After: 0.08045 seconds
Time Before: 0.11071 seconds
Time After: 0.11203 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.11488318443298
Time Before: 0.12156 seconds
Time After: 0.12174 seconds
Time Before: 0.12412 seconds
Time After: 0.12561 seconds
SET lastactivity = 1785386396, location = '/forums/private.php?do=newpm&explain=1&u=103218', badlocation = 1
WHERE sessionhash = '1b43d45bbaaa70ba8be59b846adc9cfa'
Time Before: 0.14657 seconds
Time After: 0.14690 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.1455180644989 seconds with 9 queries, spending 0.0079813003540039 doing MySQL queries and 0.1375367641449 doing PHP things.
