Time Before: 0.00143 seconds
Time After: 0.00197 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00204 seconds
Time After: 0.00273 seconds
Time Taken: 0.00069 seconds
Time Before: 0.00299 seconds
Time After: 0.00312 seconds
Time Before: 0.00378 seconds
Time After: 0.00663 seconds
Time Taken: 0.00285 seconds
Time Before: 0.00317 seconds
Time After: 0.01007 seconds
Time Taken: 0.00690 seconds
Time Before: 0.01193 seconds
Time After: 0.01242 seconds
Time Before: 0.01500 seconds
Time After: 0.01635 seconds
Time Taken: 0.00135 seconds
Time Before: 0.01127 seconds
Time After: 0.01653 seconds
Time Taken: 0.00525 seconds
Time Before: 0.02180 seconds
Time After: 0.02200 seconds
Time Before: 0.02393 seconds
Time After: 0.02522 seconds
End call of global.php: 0.026826858520508
Time Before: 0.02807 seconds
Time After: 0.02826 seconds
Time Before: 0.03018 seconds
Time After: 0.03166 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=10322'
Time Before: 0.04407 seconds
Time After: 0.04439 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.04316782951355 seconds with 9 queries, spending 0.0089786052703857 doing MySQL queries and 0.034189224243164 doing PHP things.
