Time Before: 0.02522 seconds
Time After: 0.03563 seconds
Time Taken: 0.01041 seconds
Time Before: 0.03574 seconds
Time After: 0.03620 seconds
Time Before: 0.03643 seconds
Time After: 0.03657 seconds
Time Before: 0.03730 seconds
Time After: 0.03957 seconds
Time Taken: 0.00226 seconds
Time Before: 0.03662 seconds
Time After: 0.04423 seconds
Time Taken: 0.00761 seconds
Time Before: 0.05213 seconds
Time After: 0.05253 seconds
Time Before: 0.05494 seconds
Time After: 0.05623 seconds
Time Before: 0.05149 seconds
Time After: 0.05644 seconds
Time Taken: 0.00495 seconds
Time Before: 0.08364 seconds
Time After: 0.08377 seconds
Time Before: 0.10328 seconds
Time After: 0.10456 seconds
Time Before: 0.11433 seconds
Time After: 0.11448 seconds
Time Before: 0.11680 seconds
Time After: 0.11826 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=103231', badlocation = 1 WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.13613 seconds
Time After: 0.13641 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
