Time Before: 0.01902 seconds
Time After: 0.02592 seconds
Time Taken: 0.00690 seconds
Time Before: 0.02603 seconds
Time After: 0.02652 seconds
Time Before: 0.02676 seconds
Time After: 0.02693 seconds
Time Before: 0.02769 seconds
Time After: 0.03009 seconds
Time Taken: 0.00240 seconds
Time Before: 0.02698 seconds
Time After: 0.03454 seconds
Time Taken: 0.00755 seconds
Time Before: 0.04203 seconds
Time After: 0.04226 seconds
Time Before: 0.04454 seconds
Time After: 0.04601 seconds
Time Before: 0.04136 seconds
Time After: 0.04624 seconds
Time Taken: 0.00488 seconds
Time Before: 0.07518 seconds
Time After: 0.07538 seconds
Time Before: 0.22328 seconds
Time After: 0.22457 seconds
Time Before: 0.23474 seconds
Time After: 0.23495 seconds
Time Before: 0.23759 seconds
Time After: 0.23906 seconds
UPDATE session SET lastactivity = 1776602626, location = '/forums/private.php?do=newpm&explain=1&u=103271' WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.25791 seconds
Time After: 0.26123 seconds
Time Taken: 0.00332 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
