Time Before: 0.00140 seconds
Time After: 0.00196 seconds
Time Taken: 0.00056 seconds
Memory Before: 534.492 KB
Memory After: 559.609 KB
Time Before: 0.00203 seconds
Time After: 0.00243 seconds
Memory Before: 559.547 KB
Memory After: 560.555 KB
Time Before: 0.00272 seconds
Time After: 0.00285 seconds
Memory Before: 561.109 KB
Memory After: 561.633 KB
Time Before: 0.00359 seconds
Time After: 0.00608 seconds
Time Taken: 0.00249 seconds
Memory Before: 564.234 KB
Memory After: 565.156 KB
Time Before: 0.00290 seconds
Time After: 0.00958 seconds
Time Taken: 0.00668 seconds
Memory Before: 560.883 KB
Memory After: 1,641.883 KB
Memory Used: 1,081.000 KB
Time Before: 0.01134 seconds
Time After: 0.01172 seconds
Memory Before: 2,136.727 KB
Memory After: 2,137.344 KB
Time Before: 0.01315 seconds
Time After: 0.01437 seconds
Memory Before: 2,148.906 KB
Memory After: 2,148.766 KB
Time Before: 0.01081 seconds
Time After: 0.01461 seconds
Time Taken: 0.00380 seconds
Memory Before: 2,128.906 KB
Memory After: 2,261.789 KB
Time Before: 0.02223 seconds
Time After: 0.02238 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.02473 seconds
Time After: 0.02597 seconds
Memory Before: 2,903.656 KB
Memory After: 2,904.250 KB
End call of global.php: 0.027721881866455
Time Before: 0.02889 seconds
Time After: 0.02903 seconds
Memory Before: 3,540.422 KB
Memory After: 3,540.852 KB
Time Before: 0.03101 seconds
Time After: 0.03247 seconds
Memory Before: 3,821.953 KB
Memory After: 3,823.641 KB
SET lastactivity = 1784906007, location = '/forums/private.php?do=newpm&explain=1&u=103294'
WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.04754 seconds
Time After: 0.05293 seconds
Time Taken: 0.00539 seconds
Memory Before: 4,295.914 KB
Memory After: 4,296.141 KB
Page generated in 0.046660900115967 seconds with 9 queries, spending 0.013005018234253 doing MySQL queries and 0.033655881881714 doing PHP things.
