Time Before: 0.00151 seconds
Time After: 0.00198 seconds
Time Before: 0.00206 seconds
Time After: 0.00256 seconds
Time Before: 0.00280 seconds
Time After: 0.00293 seconds
Time Before: 0.00362 seconds
Time After: 0.00589 seconds
Time Taken: 0.00227 seconds
Time Before: 0.00299 seconds
Time After: 0.00931 seconds
Time Taken: 0.00633 seconds
Time Before: 0.01121 seconds
Time After: 0.01158 seconds
Time Before: 0.01399 seconds
Time After: 0.01525 seconds
Time Before: 0.01062 seconds
Time After: 0.01547 seconds
Time Taken: 0.00486 seconds
Time Before: 0.02206 seconds
Time After: 0.02220 seconds
Time Before: 0.02397 seconds
Time After: 0.02525 seconds
End call of global.php: 0.026873111724854
Time Before: 0.02825 seconds
Time After: 0.02849 seconds
Time Before: 0.03049 seconds
Time After: 0.03202 seconds
Time Taken: 0.00153 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=103298'
WHERE sessionhash = '785a5ccc852039ad054a2e3a39163c15'
Time Before: 0.04515 seconds
Time After: 0.04549 seconds
Memory Before: 4,911.586 KB
Memory After: 4,911.828 KB
Page generated in 0.04423713684082 seconds with 9 queries, spending 0.0080699920654297 doing MySQL queries and 0.036167144775391 doing PHP things.
