Time Before: 0.00130 seconds
Time After: 0.00175 seconds
Time Before: 0.00182 seconds
Time After: 0.00241 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00263 seconds
Time After: 0.00280 seconds
Time Before: 0.00352 seconds
Time After: 0.00610 seconds
Time Taken: 0.00258 seconds
Time Before: 0.00285 seconds
Time After: 0.00968 seconds
Time Taken: 0.00682 seconds
Time Before: 0.01192 seconds
Time After: 0.01233 seconds
Time Before: 0.01549 seconds
Time After: 0.01666 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01127 seconds
Time After: 0.01687 seconds
Time Taken: 0.00560 seconds
Time Before: 0.02216 seconds
Time After: 0.02230 seconds
Time Before: 0.02460 seconds
Time After: 0.02584 seconds
Time Before: 0.03025 seconds
Time After: 0.03041 seconds
Time Before: 0.03331 seconds
Time After: 0.03483 seconds
Time Taken: 0.00152 seconds
UPDATE session SET lastactivity = 1789117096, location = '/forums/private.php?do=newpm&explain=1&u=103307', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.05142 seconds
Time After: 0.05173 seconds
