Time Before: 0.01432 seconds
Time After: 0.02001 seconds
Time Taken: 0.00568 seconds
Time Before: 0.02010 seconds
Time After: 0.02054 seconds
Time Before: 0.02076 seconds
Time After: 0.02089 seconds
Time Before: 0.02172 seconds
Time After: 0.02390 seconds
Time Taken: 0.00218 seconds
Time Before: 0.02098 seconds
Time After: 0.02785 seconds
Time Taken: 0.00687 seconds
Time Before: 0.03726 seconds
Time After: 0.03812 seconds
Time Taken: 0.00086 seconds
Time Before: 0.04079 seconds
Time After: 0.04230 seconds
Time Taken: 0.00151 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.03647 seconds
Time After: 0.04256 seconds
Time Taken: 0.00609 seconds
Memory After: 2,261.820 KB
Time Before: 0.07434 seconds
Time After: 0.07449 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.10062 seconds
Time After: 0.10196 seconds
Time Taken: 0.00135 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.11343 seconds
Time After: 0.11392 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.11635 seconds
Time After: 0.11786 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789044108, location = '/forums/private.php?do=newpm&explain=1&u=103329', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.13897 seconds
Time After: 0.13935 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
