Time Before: 0.00150 seconds
Time After: 0.00200 seconds
Time Before: 0.00207 seconds
Time After: 0.00275 seconds
Time Taken: 0.00068 seconds
Time Before: 0.00301 seconds
Time After: 0.00315 seconds
Time Before: 0.00399 seconds
Time After: 0.00700 seconds
Time Taken: 0.00301 seconds
Time Before: 0.00320 seconds
Time After: 0.01191 seconds
Time Taken: 0.00871 seconds
Time Before: 0.01396 seconds
Time After: 0.01444 seconds
Time Before: 0.01605 seconds
Time After: 0.01740 seconds
Time Taken: 0.00135 seconds
Time Before: 0.01326 seconds
Time After: 0.01758 seconds
Time Taken: 0.00433 seconds
Time Before: 0.02290 seconds
Time After: 0.02306 seconds
Time Before: 0.02559 seconds
Time After: 0.02704 seconds
End call of global.php: 0.028717041015625
Time Before: 0.03001 seconds
Time After: 0.03016 seconds
Time Before: 0.03235 seconds
Time After: 0.03389 seconds
Time Taken: 0.00154 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=103330', badlocation = 1
WHERE sessionhash = 'b1e9f976e3e130f3a0e1c3e688e54b68'
Time Before: 0.04878 seconds
Time After: 0.04904 seconds
Page generated in 0.047836065292358 seconds with 9 queries, spending 0.0092160701751709 doing MySQL queries and 0.038619995117188 doing PHP things.
