Time Before: 0.00957 seconds
Time After: 0.01193 seconds
Time Taken: 0.00237 seconds
Time Before: 0.01203 seconds
Time After: 0.01238 seconds
Time Before: 0.01266 seconds
Time After: 0.01281 seconds
Time Before: 0.01363 seconds
Time After: 0.01709 seconds
Time Taken: 0.00346 seconds
Time Before: 0.01290 seconds
Time After: 0.02210 seconds
Time Taken: 0.00920 seconds
Time Before: 0.02574 seconds
Time After: 0.02609 seconds
Time Before: 0.02759 seconds
Time After: 0.02889 seconds
Time Taken: 0.00131 seconds
Time Before: 0.02508 seconds
Time After: 0.02913 seconds
Time Taken: 0.00405 seconds
Time Before: 0.04931 seconds
Time After: 0.04951 seconds
Time Before: 0.05922 seconds
Time After: 0.06045 seconds
Time Before: 0.06627 seconds
Time After: 0.06643 seconds
Time Before: 0.06923 seconds
Time After: 0.07064 seconds
UPDATE session SET lastactivity = 1776789537, location = '/forums/private.php?do=newpm&explain=1&u=103332', badlocation = 1 WHERE sessionhash = '84d505ff74940a4d05f0ae95a61eba7a'
Time Before: 0.08736 seconds
Time After: 0.08768 seconds
