Time Before: 0.02423 seconds
Time After: 0.03112 seconds
Time Taken: 0.00688 seconds
Time Before: 0.03124 seconds
Time After: 0.03171 seconds
Time Before: 0.03202 seconds
Time After: 0.03216 seconds
Time Before: 0.03305 seconds
Time After: 0.03530 seconds
Time Taken: 0.00224 seconds
Time Before: 0.03225 seconds
Time After: 0.04003 seconds
Time Taken: 0.00778 seconds
Time Before: 0.05017 seconds
Time After: 0.05059 seconds
Time Before: 0.05336 seconds
Time After: 0.05456 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.04945 seconds
Time After: 0.05482 seconds
Time Taken: 0.00537 seconds
Memory After: 2,261.703 KB
Time Before: 0.07335 seconds
Time After: 0.07348 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.09350 seconds
Time After: 0.09472 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.10363 seconds
Time After: 0.10377 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.10639 seconds
Time After: 0.10783 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=103356', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.12812 seconds
Time After: 0.12837 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
