Time Before: 0.02372 seconds
Time After: 0.02676 seconds
Time Taken: 0.00303 seconds
Time Before: 0.02687 seconds
Time After: 0.02727 seconds
Time Before: 0.02759 seconds
Time After: 0.02776 seconds
Time Before: 0.02857 seconds
Time After: 0.03089 seconds
Time Taken: 0.00232 seconds
Time Before: 0.02784 seconds
Time After: 0.03486 seconds
Time Taken: 0.00702 seconds
Time Before: 0.04159 seconds
Time After: 0.04202 seconds
Time Before: 0.04520 seconds
Time After: 0.04651 seconds
Time Taken: 0.00131 seconds
Time Before: 0.04086 seconds
Time After: 0.04676 seconds
Time Taken: 0.00590 seconds
Time Before: 0.08318 seconds
Time After: 0.08331 seconds
Time Before: 0.09985 seconds
Time After: 0.10115 seconds
Time Before: 0.10846 seconds
Time After: 0.10862 seconds
Time Before: 0.11183 seconds
Time After: 0.11326 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=10339' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.13266 seconds
Time After: 0.13308 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
