Time Before: 0.00223 seconds
Time After: 0.00284 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00294 seconds
Time After: 0.00338 seconds
Time Before: 0.00362 seconds
Time After: 0.00374 seconds
Time Before: 0.00458 seconds
Time After: 0.00676 seconds
Time Taken: 0.00219 seconds
Time Before: 0.00380 seconds
Time After: 0.01170 seconds
Time Taken: 0.00789 seconds
Time Before: 0.01379 seconds
Time After: 0.01423 seconds
Time Before: 0.01685 seconds
Time After: 0.01806 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01315 seconds
Time After: 0.01829 seconds
Time Taken: 0.00515 seconds
Memory After: 2,261.703 KB
Time Before: 0.02400 seconds
Time After: 0.02413 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02643 seconds
Time After: 0.02764 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.03064 seconds
Time After: 0.03080 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03287 seconds
Time After: 0.03431 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=103391' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04987 seconds
Time After: 0.05015 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
