Time Before: 0.00204 seconds
Time After: 0.00266 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00277 seconds
Time After: 0.00335 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00356 seconds
Time After: 0.00369 seconds
Time Before: 0.00451 seconds
Time After: 0.00711 seconds
Time Taken: 0.00259 seconds
Time Before: 0.00374 seconds
Time After: 0.01053 seconds
Time Taken: 0.00680 seconds
Time Before: 0.01251 seconds
Time After: 0.01292 seconds
Time Before: 0.01591 seconds
Time After: 0.01728 seconds
Time Taken: 0.00137 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01183 seconds
Time After: 0.01747 seconds
Time Taken: 0.00564 seconds
Memory After: 2,261.820 KB
Time Before: 0.02292 seconds
Time After: 0.02305 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02505 seconds
Time After: 0.02629 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.028661012649536
Time Before: 0.03060 seconds
Time After: 0.03074 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03278 seconds
Time After: 0.03420 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1788871585, location = '/forums/private.php?do=newpm&explain=1&u=103430'
Time Before: 0.04703 seconds
Time After: 0.04772 seconds
Time Taken: 0.00069 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
Page generated in 0.046130895614624 seconds with 9 queries, spending 0.0087149143218994 doing MySQL queries and 0.037415981292725 doing PHP things.
