Time Before: 0.00134 seconds
Time After: 0.00179 seconds
Time Before: 0.00186 seconds
Time After: 0.00247 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00270 seconds
Time After: 0.00282 seconds
Time Before: 0.00354 seconds
Time After: 0.00622 seconds
Time Taken: 0.00267 seconds
Time Before: 0.00287 seconds
Time After: 0.00973 seconds
Time Taken: 0.00687 seconds
Time Before: 0.01177 seconds
Time After: 0.01223 seconds
Time Before: 0.01514 seconds
Time After: 0.01637 seconds
Time Before: 0.01108 seconds
Time After: 0.01653 seconds
Time Taken: 0.00545 seconds
Time Before: 0.02189 seconds
Time After: 0.02208 seconds
Time Before: 0.02429 seconds
Time After: 0.02562 seconds
Time Taken: 0.00134 seconds
End call of global.php: 0.027351140975952
Time Before: 0.02899 seconds
Time After: 0.02921 seconds
Time Before: 0.03150 seconds
Time After: 0.03290 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=103444', badlocation = 1
Time Before: 0.04568 seconds
Time After: 0.04602 seconds
Page generated in 0.044463157653809 seconds with 9 queries, spending 0.0085844993591309 doing MySQL queries and 0.035878658294678 doing PHP things.
