Time Before: 0.00258 seconds
Time After: 0.00332 seconds
Time Taken: 0.00074 seconds
Time Before: 0.00339 seconds
Time After: 0.00390 seconds
Time Before: 0.00421 seconds
Time After: 0.00436 seconds
Time Before: 0.00530 seconds
Time After: 0.00766 seconds
Time Taken: 0.00236 seconds
Time Before: 0.00444 seconds
Time After: 0.01266 seconds
Time Taken: 0.00822 seconds
Time Before: 0.01458 seconds
Time After: 0.01494 seconds
Time Before: 0.01745 seconds
Time After: 0.01866 seconds
Time Before: 0.01398 seconds
Time After: 0.01886 seconds
Time Taken: 0.00488 seconds
Time Before: 0.02685 seconds
Time After: 0.02700 seconds
Time Before: 0.03098 seconds
Time After: 0.03221 seconds
Time Before: 0.03581 seconds
Time After: 0.03598 seconds
Time Before: 0.03793 seconds
Time After: 0.03937 seconds
UPDATE session SET lastactivity = 1783102600, location = '/forums/private.php?do=newpm&explain=1&u=103500', badlocation = 1 WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.05229 seconds
Time After: 0.05260 seconds
