Time Before: 0.00174 seconds
Time After: 0.00228 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00235 seconds
Time After: 0.00273 seconds
Time Before: 0.00307 seconds
Time After: 0.00323 seconds
Time Before: 0.00412 seconds
Time After: 0.00646 seconds
Time Taken: 0.00234 seconds
Time Before: 0.00331 seconds
Time After: 0.00986 seconds
Time Taken: 0.00655 seconds
Time Before: 0.01155 seconds
Time After: 0.01194 seconds
Time Before: 0.01509 seconds
Time After: 0.01628 seconds
Time Before: 0.01099 seconds
Time After: 0.01654 seconds
Time Taken: 0.00555 seconds
Time Before: 0.02437 seconds
Time After: 0.02452 seconds
Time Before: 0.02646 seconds
Time After: 0.02769 seconds
End call of global.php: 0.02934193611145
Time Before: 0.03065 seconds
Time After: 0.03079 seconds
Time Before: 0.03337 seconds
Time After: 0.03483 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=103506', badlocation = 1
Time Before: 0.05330 seconds
Time After: 0.05357 seconds
Page generated in 0.051983118057251 seconds with 9 queries, spending 0.0077285766601562 doing MySQL queries and 0.044254541397095 doing PHP things.
