Time Before: 0.01931 seconds
Time After: 0.02826 seconds
Time Taken: 0.00895 seconds
Time Before: 0.02836 seconds
Time After: 0.02878 seconds
Time Before: 0.02900 seconds
Time After: 0.02918 seconds
Time Before: 0.03002 seconds
Time After: 0.03236 seconds
Time Taken: 0.00234 seconds
Time Before: 0.02923 seconds
Time After: 0.03710 seconds
Time Taken: 0.00787 seconds
Time Before: 0.04773 seconds
Time After: 0.04824 seconds
Time Before: 0.05114 seconds
Time After: 0.05232 seconds
Time Taken: 0.00118 seconds
Time Before: 0.04686 seconds
Time After: 0.05250 seconds
Time Taken: 0.00565 seconds
Time Before: 0.09156 seconds
Time After: 0.09170 seconds
Time Before: 0.11360 seconds
Time After: 0.11489 seconds
Time Before: 0.12852 seconds
Time After: 0.12889 seconds
Time Before: 0.13159 seconds
Time After: 0.13305 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=103516' WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.15202 seconds
Time After: 0.15229 seconds
Memory Before: 4,911.586 KB
Memory After: 4,911.828 KB
