Time Before: 0.00700 seconds
Time After: 0.01077 seconds
Time Taken: 0.00377 seconds
Time Before: 0.01085 seconds
Time After: 0.01129 seconds
Time Before: 0.01152 seconds
Time After: 0.01171 seconds
Time Before: 0.01244 seconds
Time After: 0.01444 seconds
Time Taken: 0.00200 seconds
Time Before: 0.01177 seconds
Time After: 0.01840 seconds
Time Taken: 0.00663 seconds
Time Before: 0.02386 seconds
Time After: 0.02427 seconds
Time Before: 0.02620 seconds
Time After: 0.02752 seconds
Time Taken: 0.00133 seconds
Time Before: 0.02320 seconds
Time After: 0.02776 seconds
Time Taken: 0.00456 seconds
Time Before: 0.04336 seconds
Time After: 0.04364 seconds
Time Before: 0.05227 seconds
Time After: 0.05354 seconds
End call of global.php: 0.055642127990723
Time Before: 0.05932 seconds
Time After: 0.05957 seconds
Time Before: 0.06283 seconds
Time After: 0.06440 seconds
Time Taken: 0.00156 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=103519', badlocation = 1
Time Before: 0.07868 seconds
Time After: 0.07900 seconds
Page generated in 0.077784061431885 seconds with 9 queries, spending 0.0080604553222656 doing MySQL queries and 0.069723606109619 doing PHP things.
