Time Before: 0.02072 seconds
Time After: 0.02987 seconds
Time Taken: 0.00915 seconds
Time Before: 0.02995 seconds
Time After: 0.03036 seconds
Time Before: 0.03071 seconds
Time After: 0.03090 seconds
Time Before: 0.03166 seconds
Time After: 0.03442 seconds
Time Taken: 0.00276 seconds
Time Before: 0.03098 seconds
Time After: 0.03856 seconds
Time Taken: 0.00759 seconds
Time Before: 0.04935 seconds
Time After: 0.04978 seconds
Time Before: 0.05118 seconds
Time After: 0.05239 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.04811 seconds
Time After: 0.05268 seconds
Time Taken: 0.00457 seconds
Memory After: 2,261.820 KB
Time Before: 0.07046 seconds
Time After: 0.07061 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.09318 seconds
Time After: 0.09444 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.11088 seconds
Time After: 0.11106 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.11374 seconds
Time After: 0.11536 seconds
Time Taken: 0.00162 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789147577, location = '/forums/private.php?do=newpm&explain=1&u=103537' WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.13280 seconds
Time After: 0.13310 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
