Time Before: 0.00787 seconds
Time After: 0.01074 seconds
Time Taken: 0.00287 seconds
Time Before: 0.01083 seconds
Time After: 0.01122 seconds
Time Before: 0.01143 seconds
Time After: 0.01157 seconds
Time Before: 0.01242 seconds
Time After: 0.01504 seconds
Time Taken: 0.00262 seconds
Time Before: 0.01163 seconds
Time After: 0.02075 seconds
Time Taken: 0.00912 seconds
Time Before: 0.02470 seconds
Time After: 0.02513 seconds
Time Before: 0.02815 seconds
Time After: 0.02975 seconds
Time Taken: 0.00160 seconds
Time Before: 0.02389 seconds
Time After: 0.02993 seconds
Time Taken: 0.00604 seconds
Time Before: 0.04315 seconds
Time After: 0.04329 seconds
Time Before: 0.04912 seconds
Time After: 0.05040 seconds
Time Before: 0.05622 seconds
Time After: 0.05647 seconds
Time Before: 0.05977 seconds
Time After: 0.06135 seconds
Time Taken: 0.00158 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=103569' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.08204 seconds
Time After: 0.08241 seconds
