Time Before: 0.01253 seconds
Time After: 0.01544 seconds
Time Taken: 0.00291 seconds
Time Before: 0.01577 seconds
Time After: 0.01621 seconds
Time Before: 0.01642 seconds
Time After: 0.01653 seconds
Time Before: 0.01726 seconds
Time After: 0.01998 seconds
Time Taken: 0.00272 seconds
Time Before: 0.01658 seconds
Time After: 0.02338 seconds
Time Taken: 0.00680 seconds
Time Before: 0.02809 seconds
Time After: 0.02850 seconds
Time Before: 0.02982 seconds
Time After: 0.03111 seconds
Time Before: 0.02746 seconds
Time After: 0.03130 seconds
Time Taken: 0.00384 seconds
Time Before: 0.04993 seconds
Time After: 0.05013 seconds
Time Before: 0.06030 seconds
Time After: 0.06153 seconds
Time Before: 0.06938 seconds
Time After: 0.06954 seconds
Time Before: 0.07216 seconds
Time After: 0.07368 seconds
Time Taken: 0.00152 seconds
UPDATE session SET lastactivity = 1784866215, location = '/forums/private.php?do=newpm&explain=1&u=103600', badlocation = 1 WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.09319 seconds
Time After: 0.09348 seconds
Memory Before: 4,289.344 KB
Memory After: 4,289.555 KB
