Time Before: 0.01417 seconds
Time After: 0.02289 seconds
Time Taken: 0.00872 seconds
Time Before: 0.02300 seconds
Time After: 0.02344 seconds
Time Before: 0.02371 seconds
Time After: 0.02385 seconds
Time Before: 0.02492 seconds
Time After: 0.02683 seconds
Time Taken: 0.00192 seconds
Time Before: 0.02393 seconds
Time After: 0.03123 seconds
Time Taken: 0.00730 seconds
Time Before: 0.04194 seconds
Time After: 0.04240 seconds
Time Before: 0.04571 seconds
Time After: 0.04721 seconds
Time Taken: 0.00150 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.04121 seconds
Time After: 0.04741 seconds
Time Taken: 0.00621 seconds
Memory After: 2,261.703 KB
Time Before: 0.07110 seconds
Time After: 0.07124 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.09484 seconds
Time After: 0.09635 seconds
Time Taken: 0.00151 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.10821 seconds
Time After: 0.10836 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.11081 seconds
Time After: 0.11228 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=103608', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.13194 seconds
Time After: 0.13219 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
