Time Before: 0.01267 seconds
Time After: 0.01671 seconds
Time Taken: 0.00404 seconds
Time Before: 0.01683 seconds
Time After: 0.01724 seconds
Time Before: 0.01744 seconds
Time After: 0.01759 seconds
Time Before: 0.01840 seconds
Time After: 0.02112 seconds
Time Taken: 0.00271 seconds
Time Before: 0.01767 seconds
Time After: 0.02612 seconds
Time Taken: 0.00845 seconds
Time Before: 0.03252 seconds
Time After: 0.03300 seconds
Time Before: 0.03548 seconds
Time After: 0.03678 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03184 seconds
Time After: 0.03703 seconds
Time Taken: 0.00519 seconds
Memory After: 2,261.703 KB
Time Before: 0.05244 seconds
Time After: 0.05257 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.06612 seconds
Time After: 0.06738 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.069983005523682
Time Before: 0.07432 seconds
Time After: 0.07449 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.07690 seconds
Time After: 0.07839 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=103610'
Time Before: 0.09733 seconds
Time After: 0.09758 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
Page generated in 0.096212148666382 seconds with 9 queries, spending 0.0083475112915039 doing MySQL queries and 0.087864637374878 doing PHP things.
