Time Before: 0.00277 seconds
Time After: 0.00328 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.00336 seconds
Time After: 0.00384 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.00409 seconds
Time After: 0.00422 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.00513 seconds
Time After: 0.00803 seconds
Time Taken: 0.00291 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.00430 seconds
Time After: 0.01271 seconds
Time Taken: 0.00841 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.01478 seconds
Time After: 0.01520 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.01668 seconds
Time After: 0.01797 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.01406 seconds
Time After: 0.01821 seconds
Time Taken: 0.00416 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.02672 seconds
Time After: 0.02691 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.03604 seconds
Time After: 0.03733 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
Time Before: 0.04741 seconds
Time After: 0.04759 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.05047 seconds
Time After: 0.05195 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
UPDATE session SET lastactivity = 1772911239, location = '/forums/private.php?do=newpm&explain=1&u=103655' WHERE sessionhash = '05469e5b46550d3cbf9ccd27256b5c39'
Time Before: 0.06663 seconds
Time After: 0.06692 seconds
Memory Before: 5,998.719 KB
Memory After: 5,998.945 KB
