Time Before: 0.00580 seconds
Time After: 0.00781 seconds
Time Taken: 0.00201 seconds
Time Before: 0.00789 seconds
Time After: 0.00832 seconds
Time Before: 0.00887 seconds
Time After: 0.00903 seconds
Time Before: 0.00999 seconds
Time After: 0.01208 seconds
Time Taken: 0.00209 seconds
Time Before: 0.00910 seconds
Time After: 0.01658 seconds
Time Taken: 0.00747 seconds
Time Before: 0.02119 seconds
Time After: 0.02139 seconds
Time Before: 0.02437 seconds
Time After: 0.02556 seconds
Time Taken: 0.00118 seconds
Time Before: 0.02035 seconds
Time After: 0.02580 seconds
Time Taken: 0.00545 seconds
Time Before: 0.04140 seconds
Time After: 0.04156 seconds
Time Before: 0.04874 seconds
Time After: 0.05010 seconds
Time Taken: 0.00136 seconds
End call of global.php: 0.052445888519287
Time Before: 0.05496 seconds
Time After: 0.05512 seconds
Time Before: 0.05768 seconds
Time After: 0.05912 seconds
SET lastactivity = 1783282284, location = '/forums/private.php?do=newpm&explain=1&u=103656'
Time Before: 0.07309 seconds
Time After: 0.07342 seconds
Memory Before: 4,912.039 KB
Memory After: 4,912.266 KB
Page generated in 0.072110891342163 seconds with 9 queries, spending 0.0075223445892334 doing MySQL queries and 0.06458854675293 doing PHP things.
