Time Before: 0.00136 seconds
Time After: 0.00186 seconds
Time Before: 0.00193 seconds
Time After: 0.00248 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00271 seconds
Time After: 0.00290 seconds
Time Before: 0.00359 seconds
Time After: 0.00707 seconds
Time Taken: 0.00348 seconds
Time Before: 0.00294 seconds
Time After: 0.01049 seconds
Time Taken: 0.00755 seconds
Time Before: 0.01243 seconds
Time After: 0.01283 seconds
Time Before: 0.01516 seconds
Time After: 0.01645 seconds
Time Before: 0.01174 seconds
Time After: 0.01662 seconds
Time Taken: 0.00488 seconds
Time Before: 0.02168 seconds
Time After: 0.02191 seconds
Time Before: 0.02435 seconds
Time After: 0.02567 seconds
Time Taken: 0.00132 seconds
Time Before: 0.02957 seconds
Time After: 0.02976 seconds
Time Before: 0.03214 seconds
Time After: 0.03360 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=103662' WHERE sessionhash = 'c9ecef9835dff112a7666634a7a1b42a'
Time Before: 0.04689 seconds
Time After: 0.04717 seconds
