Time Before: 0.00179 seconds
Time After: 0.00242 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00249 seconds
Time After: 0.00290 seconds
Time Before: 0.00321 seconds
Time After: 0.00337 seconds
Time Before: 0.00409 seconds
Time After: 0.00665 seconds
Time Taken: 0.00255 seconds
Time Before: 0.00343 seconds
Time After: 0.01018 seconds
Time Taken: 0.00675 seconds
Time Before: 0.01211 seconds
Time After: 0.01251 seconds
Time Before: 0.01403 seconds
Time After: 0.01530 seconds
Time Before: 0.01134 seconds
Time After: 0.01554 seconds
Time Taken: 0.00420 seconds
Time Before: 0.02218 seconds
Time After: 0.02234 seconds
Time Before: 0.02441 seconds
Time After: 0.02566 seconds
Time Before: 0.02962 seconds
Time After: 0.02985 seconds
Time Before: 0.03250 seconds
Time After: 0.03398 seconds
UPDATE session SET lastactivity = 1782975720, location = '/forums/private.php?do=newpm&explain=1&u=103664', badlocation = 1 WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.04652 seconds
Time After: 0.04685 seconds
Memory Before: 4,912.320 KB
Memory After: 4,912.531 KB
