Time Before: 0.01162 seconds
Time After: 0.01927 seconds
Time Taken: 0.00765 seconds
Time Before: 0.01939 seconds
Time After: 0.01991 seconds
Time Before: 0.02020 seconds
Time After: 0.02032 seconds
Time Before: 0.02123 seconds
Time After: 0.02352 seconds
Time Taken: 0.00228 seconds
Time Before: 0.02041 seconds
Time After: 0.02756 seconds
Time Taken: 0.00715 seconds
Time Before: 0.03280 seconds
Time After: 0.03320 seconds
Time Before: 0.03593 seconds
Time After: 0.03717 seconds
Time Before: 0.03213 seconds
Time After: 0.03743 seconds
Time Taken: 0.00530 seconds
Time Before: 0.06415 seconds
Time After: 0.06429 seconds
Time Before: 0.07241 seconds
Time After: 0.07366 seconds
End call of global.php: 0.075773000717163
Time Before: 0.08164 seconds
Time After: 0.08182 seconds
Time Before: 0.08422 seconds
Time After: 0.08568 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=103671'
Time Before: 0.10161 seconds
Time After: 0.10553 seconds
Time Taken: 0.00392 seconds
Memory Before: 4,911.586 KB
Memory After: 4,911.828 KB
Page generated in 0.10064005851746 seconds with 9 queries, spending 0.011523246765137 doing MySQL queries and 0.089116811752319 doing PHP things.
