Time Before: 0.01196 seconds
Time After: 0.01567 seconds
Time Taken: 0.00371 seconds
Time Before: 0.01577 seconds
Time After: 0.01620 seconds
Time Before: 0.01643 seconds
Time After: 0.01655 seconds
Time Before: 0.01744 seconds
Time After: 0.01964 seconds
Time Taken: 0.00220 seconds
Time Before: 0.01662 seconds
Time After: 0.02367 seconds
Time Taken: 0.00705 seconds
Time Before: 0.03000 seconds
Time After: 0.03043 seconds
Time Before: 0.03355 seconds
Time After: 0.03475 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.02919 seconds
Time After: 0.03501 seconds
Time Taken: 0.00582 seconds
Memory After: 2,261.703 KB
Time Before: 0.05377 seconds
Time After: 0.05392 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.06691 seconds
Time After: 0.06830 seconds
Time Taken: 0.00139 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.07581 seconds
Time After: 0.07598 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.07863 seconds
Time After: 0.08013 seconds
Time Taken: 0.00150 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=103685' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.09702 seconds
Time After: 0.09728 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
