Time Before: 0.00162 seconds
Time After: 0.00221 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00228 seconds
Time After: 0.00271 seconds
Time Before: 0.00295 seconds
Time After: 0.00310 seconds
Time Before: 0.00404 seconds
Time After: 0.00676 seconds
Time Taken: 0.00272 seconds
Time Before: 0.00318 seconds
Time After: 0.01189 seconds
Time Taken: 0.00872 seconds
Time Before: 0.01382 seconds
Time After: 0.01425 seconds
Time Before: 0.01613 seconds
Time After: 0.01733 seconds
Time Before: 0.01314 seconds
Time After: 0.01757 seconds
Time Taken: 0.00443 seconds
Time Before: 0.02431 seconds
Time After: 0.02445 seconds
Time Before: 0.02695 seconds
Time After: 0.02824 seconds
Time Before: 0.03263 seconds
Time After: 0.03281 seconds
Time Before: 0.03606 seconds
Time After: 0.03755 seconds
UPDATE session SET lastactivity = 1784868290, location = '/forums/private.php?do=newpm&explain=1&u=103703' WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.05753 seconds
Time After: 0.05790 seconds
