Time Before: 0.00257 seconds
Time After: 0.00315 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00326 seconds
Time After: 0.00368 seconds
Time Before: 0.00394 seconds
Time After: 0.00407 seconds
Time Before: 0.00500 seconds
Time After: 0.00711 seconds
Time Taken: 0.00211 seconds
Time Before: 0.00415 seconds
Time After: 0.01143 seconds
Time Taken: 0.00728 seconds
Time Before: 0.01341 seconds
Time After: 0.01390 seconds
Time Before: 0.01571 seconds
Time After: 0.01691 seconds
Time Before: 0.01265 seconds
Time After: 0.01718 seconds
Time Taken: 0.00453 seconds
Time Before: 0.02307 seconds
Time After: 0.02321 seconds
Time Before: 0.02545 seconds
Time After: 0.02671 seconds
Time Before: 0.03011 seconds
Time After: 0.03033 seconds
Time Before: 0.03302 seconds
Time After: 0.03457 seconds
Time Taken: 0.00155 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=103756' WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.04901 seconds
Time After: 0.04929 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
