Time Before: 0.02264 seconds
Time After: 0.03076 seconds
Time Taken: 0.00812 seconds
Time Before: 0.03087 seconds
Time After: 0.03132 seconds
Time Before: 0.03155 seconds
Time After: 0.03170 seconds
Time Before: 0.03246 seconds
Time After: 0.03477 seconds
Time Taken: 0.00231 seconds
Time Before: 0.03175 seconds
Time After: 0.03888 seconds
Time Taken: 0.00713 seconds
Time Before: 0.04700 seconds
Time After: 0.04745 seconds
Time Before: 0.04891 seconds
Time After: 0.05010 seconds
Time Before: 0.04631 seconds
Time After: 0.05029 seconds
Time Taken: 0.00397 seconds
Time Before: 0.09283 seconds
Time After: 0.09298 seconds
Time Before: 0.11408 seconds
Time After: 0.11656 seconds
Time Taken: 0.00248 seconds
End call of global.php: 0.11933994293213
Time Before: 0.12692 seconds
Time After: 0.12729 seconds
Time Before: 0.13011 seconds
Time After: 0.13211 seconds
Time Taken: 0.00200 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=103759'
Time Before: 0.14902 seconds
Time After: 0.14927 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
Page generated in 0.14794087409973 seconds with 9 queries, spending 0.0097899436950684 doing MySQL queries and 0.13815093040466 doing PHP things.
