Time Before: 0.00795 seconds
Time After: 0.00991 seconds
Time Taken: 0.00196 seconds
Time Before: 0.00999 seconds
Time After: 0.01041 seconds
Time Before: 0.01069 seconds
Time After: 0.01082 seconds
Time Before: 0.01178 seconds
Time After: 0.01394 seconds
Time Taken: 0.00217 seconds
Time Before: 0.01090 seconds
Time After: 0.01800 seconds
Time Taken: 0.00710 seconds
Time Before: 0.02228 seconds
Time After: 0.02274 seconds
Time Before: 0.02424 seconds
Time After: 0.02540 seconds
Time Taken: 0.00116 seconds
Time Before: 0.02157 seconds
Time After: 0.02560 seconds
Time Taken: 0.00403 seconds
Time Before: 0.04251 seconds
Time After: 0.04266 seconds
Time Before: 0.05043 seconds
Time After: 0.05169 seconds
End call of global.php: 0.054018020629883
Time Before: 0.05782 seconds
Time After: 0.05798 seconds
Time Before: 0.06034 seconds
Time After: 0.06178 seconds
SET lastactivity = 1784808454, location = '/forums/private.php?do=newpm&explain=1&u=103825'
Time Before: 0.08067 seconds
Time After: 0.08105 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.079551935195923 seconds with 9 queries, spending 0.0077238082885742 doing MySQL queries and 0.071828126907349 doing PHP things.
